SuperPro -High Performance Polyurethane Bush - Group Buy
north east
To mark our company becoming an approved stockist of Superpro we have decided the best way to get these absolutely amazing products into use on your cars in a more affordable way, by offering a group buy.
im sure your all aware that on of the best modifications you can make to your evo isnt in the power department but in the handling department, so many evo's you see get power increases but then at the same time you see so many of them at sprints and tracks days powering up the main straights but then handling absolutely terrible on every corner. With my sprint car for example the biggest trio of upgrades that got me vast amounts of time of my laps were Tyres, Suspension/bushes and geometry and when replacing the majority of the bushes you realise the age of the these cars now and the bennefits that new bushes bring, no extra noise, not a harsh ride afterward but a whole better feel and more precision.
Full kits
Mitsubishi Evo 4/5/6
IT5139ADJK
Front & Rear Suspension Bush Kit (with alignment correction)
Transform the handling of your car by replacing all your rubber bushes with high performance Polyurethane bush kits from SuperPro. This kit includes our innovative range of caster and camber adjustable bush kits allowing you to change the alignment settings of the front and rear wheels. This is a must have for fast road and track prepared cars with lowered suspension. Unlike rubber which starts to deteriorate from the day it is fitted, SuperPro Polyurethane bushes are not effected when exposed to Petrol, oil, Diesel, salt, water, ultra-violet light or airborne contaminants, which means SuperPro bushes keep going long after OEM or rubber aftermarket bushes have failed. All the bushes in this kit are also covered by our unrivalled 3 Year/ 36,000 Mile warranty.
Includes:
SPF2026K Front Control Arm Lower, Rear Bush Kit With Castor Increase
SPF1715K Front Control Arm Lower, Front Bush Kit
SPF0738-14K Front Anti Roll Bar to Chassis Bush Kit
SPF2072K Rear Control Arm Lower, Shock Mounting Bush Kit
SPF2062K Rear Control Arm Upper, Inner Front Bush Kit
SPF1974K Rear Control Arm Upper, Inner Rear Bush Kit
SPF1975K Rear Differential Mounting Bush Kit
SPF2544K Rear Differential Support Mounting Bush Kit
SPF2601K Rear Toe Control Arm, Inner Bush Kit (with toe adjustment)
SPF1973K Rear Trailing Arm, Front Bush Kit
SPF2073-21KRear Anti Roll to Chassis Mounting Bush Kit
Evo 7/8/9
Control Arm, Lateral Arm, Trailing Arm, ARB & Diff Mount Alignment Kit - RS/MR/GSR
INCLUDES
1xSPF2418K
1 x DURO3741K
1xSPF2072K
1xSPF2062K
1 x SPF1975K
1xSPF1974K
1xSPF2544K
SPF2061K
1xSPF1973K
1 x SPF2489K
1xSPF1451-24K
£495 a set
Evo X
Front kit
Control Arm Front & Rear Bush Kit - Standard Alignment or caster increase
£179
Roll Centre Adjustment Kit
Extended Lower Ball joint & Bump Steer compensating track rod end - ball pin thread 12mm
£129
Roll Centre Kit
Superpro Roll Centre Kit VII - X
Now in Stock!
SuperPro Roll Centre Correction Kits for Mitsubishi Evolution VII to X!
These kits address a fundamental issue created when looking to enhance handling.
Car suspension systems have a roll centre set by chassis engineers in the design process of a vehicle to give optimum handling with minimum body roll at the required ride height and centre of gravity position.
The vehicles roll centre greatly influences how the body of the vehicle will behave when cornering and is one of the key factors in how a car ‘feels’ and how it generates feedback to the driver.
Uprated suspension on a vehicle can change the ride height and therefore change the characteristics of the roll-centre.
Contrary to popular belief, lowering a vehicles suspension does not always improve the handling.
For example, if a vehicle is lowered beyond its ideal roll centre, faster and greater levels of body roll can be generated, resulting in stability and traction being adversely affected.
The extended ball joints included in these kits compensate for changes in suspension geometry when ride –heights are lowered, counteracting the effects of the resulting repositioning of the cars roll-centre.
Consequential bump-steer issues that could be caused by extending the ball joint are corrected by the new track rod ends which are also included in the kit.
The overall effect is to restore stability and traction by achieving better tyre contact, as well as making the car more neutral and obedient to driver inputs.
£129
Rear diff Mounting kits
4 - 6 £99
7 - 9 £99
i will add all of the various pictures of the individual parts to our website over the next week or so, until then please feel free to visit SuperPro Europe Ltd - European Distributors for SuperPro Polyurethane Suspension Bushes | SuperPro Europe Ltd. to have a look further. so far we are happy to arrange for the following
any immediate purchase 10% discount
if we get x8 full kits ordered between now and 7th November 2012 a 15%
if we get x15 sets or more ordered before 7th November a 20%
** this applies to orders placed across both MLR and Evo owners forums during that timescale, along with our website, facebook etc.**
please feel free to ask any questions
north east
1 Mikeyc - 4/5/6 Full Kit
2 anon - rear kit 4/5/6
2 anon - full kit (subject to max discount)
Right folks, there was loads of you asking for this group buy and now its on its gone quiet, is there any reason or is there anything else that you want to see on here. i have updated our website
Evo 4/5/6 - Evo Parts & Performance
I have also ran this same deal on the MLR so will hopefully get the full discount for you, dont forget its perfectly fine to register an interest or to say you will have them but only if max discount is achieved, also, i have amended the group buy discount structure.
Group Buy Pricing
1-4 orders = RRP
4-7 orders = 10% off RRP pricing
8-11 orders = 15% off RRP pricing
12 orders or more = 20% off RRP pricing
Postage - £9.95 to mainland UK.
Martin can you tell me what I would need as my VI GSR has a RS Diff conversion? Any difference?
I am also planning to fit the Whiteline rear ARB Kit with drops links so any changes there?
Cheers James
north east
Cheers James
Sorry for the late reply on this James, its all down to what you want out of the car really, mine for example heas the rear rs diff and different rear lower and upper toe arms. The good thing with these is that they dont make your car drive like a pig once they are fitted, so personally for best overal gains i would recommend:
Front - Control Arm Bush Kit - Caster Adjustment - All Models £118.00
rear - Differential Mounting Kit - RS Models 4-9 £118.00
Control Arm Lower - Shock Mount £34.00
Control Arm Upper - Inner Front Bush £88.00
Control Arm Upper - Inner Rear Bush £30.60
Toe Control Arm - Inner Bush £41.60
Toe Control Arm - Inner Bush £67.60
Trailing Arm - Lower - Front Bush £58.20
The rear diff mount kit is a nice modification to have an obviously the front kit with the all important Caster adjustment, (this will really support a good geometry set up as well)
UPDATE
Please see below the range of items available from us on this group buy, its NOT just for the FULL kits, its all of the product range, please feel free to ask any questions
on our website @ Evo 4/5/6 - Evo Parts & Performance
these are for the whole range
4/5/6
7/8/9
X
ALL - Control Arm Bush Kit - Standard Alignment, All Models £118.00
ALL - Control Arm Bush Kit - Caster Adjustment - All Models £118.00
4/5/6 REAR - Control Arms, Toe Control Arm, Trailing Arm and Anti roll Bar Bush kit - GSR Models £358
ALL - Differential Mounting Kit - RS Models 4-9 £118.00
ALL - Differential Mounting Kit - GSR Models 4-9 £118.00
4/5/6
Control Arm Lower - Inner Front Bush £58.00
Control Arm Lower - Inner Rear Bush £117.00
Control Arm Lower - Inner Rear Bush £114.00
Sway Bar Mount To Chassis Bush £14.00
Differential Front Bracket Mount Bushing £99.00
Differential Mount Front Bush £70.00
Differential Front Bracket Mount Bushing £68.00
Differential Rear Bracket Mount Bushing £93.24
Sway Bar Mount To Chassis Bush £13.30
7/8/9
Control Arm, Lateral Arm, Trailing Arm, ARB & Diff Mount Kit - RS/MR Models Only KIT5151K £594
Control Arm, Lateral Arm, Trailing Arm, ARB & Diff Mount Alignment Kit - RS/MR Models Only KIT0142K £594.00
Control Arm, Lateral Arm & Trailing Arm, ARB & Diff Mount Kit - GSR Models Only KIT5265K £594.00
Control Arm, Lateral Arm & Trailing Arm, ARB & Diff Mount Alignment Kit - GSR Models only KIT5265ADJK £594.00
Control Arm, Lateral Arm & Trailing Arm Kit - RS/MR Models Only KIT5151K-RG £418.00
Control Arm Front & Rear Bush Kit - Standard Alignment KIT5151CAK £214.80
Control Arm Front & Rear Bush Kit - Offset for Caster Increase KIT5151CADJK £214.80
Differential Mounting Kit - RS Models KIT5139DMK £118.00
Differential Mounting Kit - GSR Models KIT5264DMK £118.00
Control Arm Lower - Inner Front Bush SPF2418K £58.80
Control Arm Lower - Inner Rear Bush DURO3739K £162
Control Arm Lower - Inner Rear Bush DURO3741K £162
Steering Rack & Pinion Mount - Power SPF2489K £44.30
Sway Bar Mount To Chassis Bush SPF1451-_ _K £13.32
Roll Centre Adjusting Kit TRC0001 £154.00
Control Arm Lower - Shock Mount SPF2072K £33.94
Control Arm Upper - Inner Front Bush SPF2062K £88.33
Control Arm Upper - Inner Rear Bush SPF1974K £30.60
Differential Front Bracket Mount Bushing SPF2543K £98.90
Differential Mount Front Bush SPF1975K £70.36
Differential Front Bracket Mount Bushing SPF2546K £68.00
Differential Rear Bracket Mount Bushing SPF2544K £93.00
Sway Bar Mount To Chassis Bush SPF2073-_ _K £13.33
Toe Control Arm - Inner Bush SPF2063K £82.58
Toe Control Arm - Inner Bush SPF2601K £70.00
Trailing Arm - Lower - Front Bush SPF1973K £58.16
EVO X
Control Arm Front & Rear Bush Kit - Standard Alignment KIT5297CAK £214.00
Control Arm Front & Rear Bush Kit - Offset for Caster Increase KIT5297CADJK £214.00
Control Arm Lower - Inner Rear Bush DURO3439K £162.00
Control Arm Lower - Inner Rear Bush DURO3441K £162.00
Sway Bar Mount To Chassis Bush SPF3362-25K £24.50
Roll Centre Adjusting Kit TRC0004 £154.80
Control Arm Upper - Inner Front Bush SPF2418K £58.80
Sway Bar Mount To Chassis Bush SPF3362-23K £24.50
ALSO - I HAVE GOT THE FIRST X5 ORDERS IN FROM ANOTHER WEBSITE SO THE FIRST 10% APPLIES AS A MINIMUM - LETS GET THIS TO MAX DISCOUNT
north east
Just to let you know that have now hit the magic numbers for the 20% discount to be offered, i will update the first page shortly but ALL now with 20% discount
ALL ORDERS NOW WITH 20 DISCOUNT GUARANTEED
north east
Martin sorry for the delay in replying but I was stuck on the naughty step!!lol! What was the price of the kit I needed?
Cheers James
TOTAL (WITH 20% DISCOUNT) £357.44
north east
Martin, What is the price for full evo 9 (GSR/FQ320) bush kit and Roll centre kit?
just to let you guys know that we are about to take payments on the goods and will be putting the order in at the same time, as always the list of "in" people is quite as straightforward as we would have hoped but never the less we shall move forwards with this
martin
P.S WE NO TAKE CARD PAYMENT OVER THE PHONE
if anybody else would like anything please let e know quickly
