Discussion in 'How To' started by Simon@NTS, Feb 18, 2011.
Advert:
  1. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    Right im going to make this as basic as i can, please feel free to add or correct me on anything.
    Firstly your going to have to spend cash:cry:, you first need a lead to connect to the car, either a openport 1.3U or a tactrix 2.0 these can cost from 80 to 180 pound, OP1.3U can do 7/8/9, 2.0 can do 4/5/6, you will also need to get a copy of EcuFlash which is free to download
    Once Ecuflash and the cable is installed you need to take a download of your ROM
    You might also need to run the EcuFlash ECU Unlocker, which can be found at ActiveMatrix, this needs to be run first before Ecuflash
    #1
  2. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    Taking a download
    Once Ecuflash is started and the cable is connected you should see this
      File size:
      83.1 KB
      833
    #2
  3. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    Once youve took a download you should see the below, it will vary depending on rom on your evo, hopefuly you`ll have similar below, to add PLEASE save your rom as if its EcuTek ed if you overwright it, you will lose the license so if you decide to have it remapped will have to pay extra, save the original ROM and keep it safe
      File size:
      91.6 KB
      823
    #3
  4. Nick
    Nick Superstar Admin
    Staff Member
    May 6, 2008
    2,392
    151
    Please keep How To threads just for technical stuff.
    #4
  5. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    On the above pic you can see ALS if not you need to change your ROM or modify your XML to show it, which i will explain later. when you expand ALS you will see the following:-
      File size:
      100.6 KB
      849
    #5
  6. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    as a base setting you need to change the ALS settings to the following:-
    24 kph
    50 celcius
    3000 units
    80 units
    1 s
    2 s
    80 units
    12 s
    0.1 s
    0.1 s
    4.8 s
    0.7,1.3,1.8,2.0,2.4,2.4,2.4,2.4,1.6
    open each section and change in order
    #6
  7. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    this should give you mild pops and bangs but to add to the effect you need to add some negative timing to the timing map..........the problem by adding negative timing to the timing map it directly effects driveability to low load area ie when cruising, so people like to have switchable maps which is controlled by the ICS button on the centre console but this is what you should adjust in the timing map
      File size:
      108.1 KB
      860
    #7
  8. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    you can carry the negative timing over to 30 load but thats on preference
    #8
  9. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    Right when once you have changed the ALS settings and added some negative timing you can upload the ROM back into the ecu, make sure battery condition is good and you dont switch the ignition off for any reason when uploading the ROM, you can do this by pressing the write to ecu button
      File size:
      106.9 KB
      791
    #9
  10. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    Soon i will be making another how to on taking ecu downloads, changing roms and xmls
    #10
  11. sponners
    sponners Well-Known Member
    Nov 8, 2009
    1,128
    37
    nice one matey, dont think anyone on here is interested though.....prefer to give someone a tenner and have them do it for them.
    #11
  12. Simon@NTS
    Simon@NTS Trader
    Feb 13, 2011
    3,880
    463
    sponners if you want to add or correct on anything feel free, i want to do a change your rom one and eventually self mapping which is going to be the beast of a write up;)
    #12
  13. stevolution2010
    stevolution2010 New Member
    Aug 31, 2010
    2,212
    25
    ive got mixed opinions on this some people say it damages your engine
    some dont,whats the truth?
    #13
  14. mark.
    mark. New Member
    Jan 13, 2011
    324
    2
    exactly, as everybody no's on here i'm absolutly fantastic on a computer i can do anything on one but i would rather give u a tenner to do it :whistling::whistling::whistling::whistling::whistling:
    #14
  15. Nickygixer-k5
    Nickygixer-k5 Well-Known Member
    Nov 2, 2010
    4,912
    186
    Gis a tenner and I'll tell you how to change your av:whistling::whistling:
    #15
  16. mark.
    mark. New Member
    Jan 13, 2011
    324
    2
    deal lol:arms:
    #16
  17. evogeof
    evogeof Super Moderator
    Sep 11, 2010
    10,888
    538
    ill change it for £9.99 ;)
    #17
  18. Nickygixer-k5
    Nov 2, 2010
    4,912
    186
    Got to go shopping will pm you later , oh and keep the tenner;)
    #18
  19. mark.
    mark. New Member
    Jan 13, 2011
    324
    2
    i will geof my buddy is gonna do it for 9.99 :awesome:
    #19
  20. ElDopesta
    ElDopesta New Member
    Jun 2, 2009
    5,703
    144
    Oi!
    Get over to the other Pops and Bangs Thread you comedians.
    Not you Sponners, you can stay buddy!!! ;)
    evodave likes this.
Share This Page
Advert:
