Yeah im sure its the innovate he is using with a bosch wide band sensor
Its a 5" scorpian tail pipe but the system is 3", so it dose have a step in it, Herman has a clap for the tail but it has no extention, herman tried putting the wide band at an angle so it was in the flow of gasses but the afr was the same, This bung I get fitted should eliminate any issues with that. Dont think that would be causing it because the injector duty would be ok but its at 104% at 7000 rpm?
We replaced the 260 pink injectors for the fq burgundy/red injectors to see if this would cure the fault originally, herman changed some settings for these injectors
What should the injector settings be to run these injectors?
