Evo 7, no spark , no fuel pump , engine cranks but does not start!
Discussion in 'Evo Chat' started by Lucas, May 4, 2012.
Advert:
  1. Lucas
    Lucas New Member
    May 4, 2012
    6
    0
    Hi,
    My evo 7 was running fine untill the this morning i started it and it cut out after 5 seconds, then it would not start
    The engine cranks, all electics works, but it will not start!
    There is no spark from the plugs, and the fuel pump is not kicking in, i have tested the fuel pump and that works fine.
    I have checked all relays and fuse´s they all seem ok.
    I´m thinking to get a crank angle sensor? but not sure if it is the issue.
    ( is there any way of checking)
    It would be much appricated if anybody could help me out.
    cheers
    #1
  2. matthew1873
    matthew1873 Member
    Nov 1, 2011
    61
    3
    Can you pin out pins 1 and 4 on the OBD and put the fault codes up mate?
    Meant to say have a read here http://www.evoowners.co.uk/f10/no-spark-evo-7-a-8211.html#axzz1tv8qOEhf
    Matthew
    #2
  3. rigpig
    rigpig New Member
    Aug 1, 2011
    116
    5
    Sounds like it could be the imobiliser !!!
    #3
  4. evo arm's m7960
    evo arm's m7960 Well-Known Member
    Jun 26, 2011
    2,223
    118
    hi
    this sounds very simular to some one on here who broke there balance shaft belt and it took out the crank sensor :O(
    follow Matthew link :O)
    #4
  5. mikey-evo7
    mikey-evo7 New Member
    Jan 18, 2012
    219
    4
    Hi, i had exact same problem mate, it was my crank shaft sensor. I have one for sale if u need one as im breaking my evo
    #5
  6. fq-craigus
    fq-craigus Well-Known Member
    Jul 24, 2010
    8,139
    603
    How comes ur breakin now mikey
    #6
  7. Lucas
    Lucas New Member
    May 4, 2012
    6
    0
    All sorted now, i'm going to sound like a right idiot saying this but it was just a engine fuse which blew,
    I tested all the sensor's and read the whole lancer workshop manual :arms:
    Was pulling my hair out for days thinking what it could be haha.
    Anyway thank you for the replies. :D
    #7
  8. rigpig
    rigpig New Member
    Aug 1, 2011
    116
    5
    Glad you got it sorted mate.
    #8
Share This Page
Advert:
