evo 8 turnes over but will not fire up
Discussion in 'Tech Questions & How To Guides' started by redevokev, May 21, 2012.
Advert:
  1. redevokev
    redevokev New Member
    Dec 23, 2011
    27
    0
    hi, having a few issues with my evo, on ignition all the lights come up on the dash and turnes over but the pump doesnt seem to prime??? iv checked the fuses and there fine, theres power in the fuse box where the fuel pump fuse is, iv had the pump out the tank and connected it to a battery and it works fine, theres no power in the plug that connects to the fuel sender unit, any ideas on what else to check? and could the imobalizer have anything to do with this? as sunday i was out all day and it was fine then this morning when i was going to work it wouldnt start :cry: any help or recomendations on this would be much apreshiated, thanks.
    #1
  2. Steve220
    Steve220 New Member
    Jan 20, 2011
    1,093
    46
    What alarm have you got on it?
    #2
  3. trackday
    trackday New Member
    May 2, 2011
    437
    25
    I would be looking at the alarm/ immobliser mate
    #3
  4. evo arm's m7960
    evo arm's m7960 Well-Known Member
    Jun 26, 2011
    2,223
    118
  5. redevokev
    Dec 23, 2011
    27
    0
    hi,mate its a cobra alarm imobilizer
    #5
  6. chrishfq300
    chrishfq300 New Member
    Feb 14, 2011
    557
    8
    Remove the kick panel on the left hand side of the passenger footwell and check the blocks of multiplugs that connect the loom. It's common to get an ingress of water from the NSF wheel down the wiring harness, water just sits in the bottom of the plugs and rots the wiring.
    #6
Share This Page
Advert:
