Evo X - Timing Chain replacement?
Discussion in 'Tech Questions & How To Guides' started by dphillips0204, Sep 12, 2016.
  1. dphillips0204
    dphillips0204 New Member
    Sep 12, 2016
    Good afternoon all,
    I've had the red triangle exclamation mark come up to the Evo this week and from looking in the manual it's showing as a timing chain issue. Reading various forums, these need to be replaced at approx. 60,000 miles.
    Mine's only done 32k, so bit concerned that it could be another issue? I've stopped driving it until I get it sorted.
    I've also asked an Evo specialist garage who advised me "9 times out of 10 it isn't a sensor fault and the belt needs replacing". They are quoting £850 + VAT.
    Does anyone think that it could be something else? or has anyone else had to replace theirs at this early mileage?
    Any advice would be greatly appreciated....
    Many thanks in advance.
  2. Cragga
    Cragga Member
    Jan 10, 2013
    Mine was replaced at 35k, you can get it done cheaper than that- check indigo gt
    There is a new style timing chain because the original was largely not up to the job, although some people have had no issue.
    It's best not to leave it as the chain could jump and cause damage to the engine/valves.
    The car ran noticeably better after I had mine fixed/updated.
Share This Page
