irritating sound
Discussion in 'Evo Chat' started by ron23, Nov 12, 2010.
Advert:
  1. ron23
    ron23 New Member
    Oct 25, 2010
    186
    2
    Hello guyz..for 2days now ....been hearing some noise coming from the front.('am not sure if that is front wheels..tire rod or ball joints...can really hear it in lower speed...any ideas? And if it falls to those i mentioned how roughly will cost?
    Thanks
    #1
  2. sponners
    sponners Well-Known Member
    Nov 8, 2009
    1,128
    37
    quite hard to diagnose something like that over the tinterweb mate, maybe get a vid up on youtube to give aus an idea.
    #2
  3. stevolution2010
    stevolution2010 New Member
    Aug 31, 2010
    2,212
    25
    your best bet is to jack the front of the car up then once the wheel is off the ground put 1 hand at the top of the wheel in the centre the other hand on the bottom rock wheel forwards with the top hand and pull back with the bottom
    if there is any play in it then its your ball joint 9times out of ten
    then try holding the wheel i hand left side in the centre other hand right side in the centre
    rock wheel again if theres any play from this could be track rod end or wheel bearing
    if u try both of these and either gives u play in the wheel then u have a problem
    if its not something u think u can do yourself then consult a mechanic
    hope this helps:)
    #3
    ron23 likes this.
  4. stevolution2010
    Aug 31, 2010
    2,212
    25
    does it happen in straight lines or when cornering what type of noise?
    whurring,clicking or metal to metal?
    does the wheel feel like its going to buckle under the car when turning?
    #4
  5. ron23
    ron23 New Member
    Oct 25, 2010
    186
    2
    Thanks guyz....at the moment i will try your suggestion stevolution...then i will update you both (stevo&sponners)
    Thanks
    #5
  6. ron23
    ron23 New Member
    Oct 25, 2010
    186
    2
    Thanks
    #6
  7. ron23
    ron23 New Member
    Oct 25, 2010
    186
    2
    hey stevo...i did the things you told me..'am a bit happy bcoz' it went perfectly okay..it's all negative (thank God) i had a slight idea..i think its the running board..it's a bit loose..i will just try to sort that one...and it might stop the friction..at least it's only a minor...thanks to your adviced.....and to sponners..thanks as well
    #7
  8. stevolution2010
    Aug 31, 2010
    2,212
    25
    how about thanking me with a woot an u can say your finger slipped(hope toms reading this):whistling::whistling:
    #8
  9. ElDopesta
    ElDopesta New Member
    Jun 2, 2009
    5,703
    144
    He has already given you a WOOT buddy, don't bleed him dry!!! :razz: :whistling: :whistling: :whistling:
  10. stevolution2010
    Aug 31, 2010
    2,212
    25
    ahh my bad hadnt seen that lol was trying to wind tom up tho:whistling:
    #10
Share This Page
Advert:
