Mitsubishi Lancer Evolution Engine Codes
Discussion in 'Tech Questions & How To Guides' started by ElDopesta, Oct 13, 2010.
Advert:
Thread Status:
Not open for further replies.
  1. ElDopesta
    ElDopesta New Member
    Jun 2, 2009
    5,703
    144
    Due to the amount of queries as to what engine should be in which Evo, I have decided that it will be helpful for every one if I was to post up a comprehensive engine code list.
    Some of you may recognise it from somewhere else, but hey, help is help no matter where it comes from right;)
    The engine code/number is stamped on the front of the engine, on the left hand side, around half way down the block. A little tricky to see at the best of times!!!
    The two letters prefixed before the number sequence determine the origin and are what matters most:
    EVO I: MX, NX, PB
    EVO II: OP, QV
    EVO III: PP, SD
    EVO III/IV: TB, TE, TF, TG, TH, TJ, TK, TL, TM, TN, TR, TS
    EVO V: XG, XJ, XK, XL, XM, XN, XO, XP, XQ, XR, XS, XU
    EVO VI: AA, AB, AC, AL, AN, AO, AP, AQ, YN, YR, YS, YT, YX, YY
    EVO VI TME: BB, BC, BG, BJ, BK, BL, BM
    EVO VII: CS, CT, CX, DA, DB, DC, DG, DK, DN, GC, GL, GN, KD
    EVO VIII 260: HY (USA), JX, KL, KO, KQ
    EVO VIII: HM, HP, HQ, HR, HT, JC, JD, KS
    EVO VIII MR: JY, KA, KB, KD, KH, KJ, KK
    EVO IX: LA, LB, LD, LG, LJ, LQ, MM, MN, NB (USA)
    EVO X: 4B
    Big thanks to The Admiral, in case he is watching!!!
    This list may be updated from time to time.
    GKITCH, JakeMac, m7gsr and 2 others like this.
Thread Status:
Share This Page
Advert:
